I've just bought and installed TSDZ2 250w / 36v and it does not work.
Did I miss some button or config setting?
- Battery fully charged;
- Speed sensor installed;
- I don't have throttle lever;
- Screen is working, shows battery, shows speed, all the buttons work, I can change assist level;
- Set walk assist to ON (went to settings using power+i, then pressed i four times, VLCD5);
The engine looks dead. Tried running a bike, tried walking (hold - button for walk assist). Not a single sign of life, no sound etc.
Then installed both e-brakes - no change.Tried disconnecting speed sensor/brakes - no change.
I don't have throttle lever, tried to touch contacts with a screwdriver - no effect.
Anything else I can do before sending the bike to the nearest city service center?
