it took a lot longer than I have wished but as it is just my pet project, there was never much urgency to see it completed.
It's now done, well at least the first phase is done and I am very pleased to post some pictures here, hoping members will point me in the right direction regarding where the next development should go.
I have lent my Faro to a member of staff and I am using the Brompton to ride around town at the moment. The Cute Q70 is so quiet!
- Cute Q70 motorwheel 328 RPM
- Fit the Brompton fork exactly like the normal wheel
- uncluttered, simple wiring, no excess wires to hide
- Dual Hall, 12 magnet pedal sensor
- small but bright LCD
- smallest Lishui controller 14A
- various battery options
In this base version, the battery is in small frog format, 13AH made with Samsung 18650-29E cells.
The battery comes with light, on/off switch, lock and 2 keys.
You don't need the keys to ride the bike, only to remove the battery.
The capacity is much more than you would see in other kits but I chose it for 2 reasons:
- range: easily 40 miles
- power: climbing hills at full legal speed
This battery can also be mounted to the seat post if you so wish.
Installation:
1. remove the bottom bracket, add the pedal sensor, refit
2. fit the battery holder
3. install the LCD
4. drop the motor in
5. Connect up the controller directly to the LCD, battery, motor and pedal sensor. There is no cable loom.
Tools:
standard square taper bottom bracket removal tool.
Price:
Before 1/8/2020: £529, from 1/8/2020 when the next shipment arrives, £559.
Availability:
As soon as we clear the current backlog of kit orders (Andy does this alone).
Pictures:
Installation:
3. install the LCD
Tools:
Price:
Availability:
Pictures:
