Hi all
I took my carrera vengeance e spec bike into an independent bike shop recently after losing faith in Halfords after countless visits.Anyway i was told the problem was an intermittent crank sensor.I'm not getting pedal assist but when i turn bike upside down and turn pedals i can hear rear motor.I have looked at ecu and noticed the cable that comes out of ecu and plugs into crank sensor cable looked like it had been squashed.I peeled back the black outer casing and the 4 fine individual cables look ok but is it possible that some of the fine strands could have been broke and this is whats causing crank sensor not to function correctly.
Thank you
Thank you
