Hello all, I have just become the proud owner of a Kalkhoff Sahel Compact, it has the Impulse 2.0 motor/system with a compact display. Having looked through the manual, I can find reference to how to access the settings menu for the larger display (which allows you adjust such things as shift sensor delay), however I cannot find reference as to how to access these settings on the smaller unit (see attached image).
I wondered if this was even possible on this unit or is it something that can only be access via a dealer cable and connection to a computer?
I would just like to reduce the shift sensor delay as it is too long, this bike comes with a Nexus 8 hub gear and I know that the delay is designed to reduce input load when changing gear, but from many years experience of using these hubs it is set too long.
I can live with the bike if it is not possible, but if anyone can help that would be ace.
