Recently I found another controller which had cruise control. It is the type that when you hold the throttle at any position for longer than about twenty seconds it maintain the speed (or throttle setting not absolutely sure) set even if you release the throttle.
Blipping the throttle or pulling on a cutout brake releases the cruise control.
I have been using it for about a month now on my daily commute. I always find in the winter my thumb goes numb and cruise control seems to help prevent this. It takes some getting use to and sometimes you forget it is engaged.
Although I only have one cutout brake on the right/throttle side I also have a kill switch on the front Brompton bag too.
I would say my only concern would be if I fell off the bike before I had time to kill cruise control and the front wheel continued to spin
I guess some kind of wrist band/cutout switch would prevent this.
Regards
Jerry
Regards
Jerry
