I Know this has been asked before.....
MazB
58
I'm trying to post a technical question (strange for me I know LOL) - but when I post in the technical side it says I don't have permission, didn't realise I needed it, so I will post it here and apologise too.
I need to solder the 2 wires that cut-out the motor from the pedelec (Urban Mover 55) when you apply the brake. The one on the right works but the left one has come away with both wires.
Easy enough I thought just take the nut out slide this bit off, take that out snip wires and solder back into place.
But once I have the nut, the one that holds the whole brake and cut-out wires is off I cannot see where else I need to go, well I say that but I can see a wire ring that is loose (the right one is taught) but this is encased in some moulded thing.
I'm not explaining myself too well and I will try and post a photo of what I'm rattling about - but I know Flecc will know by my cryptic clues above and I'm hoping you can point me in the right direction :D
Cheers,
Maz
30,748
I'm afraid I'm stumped at the moment Maz, since I don't know the fine details on that model, so I don't recognise anything just from the description.
fcurran
394
Bath
www.powabyke.com
Hi Maz, this will get the bike working again but you will lose the brake cut off feature.
Either seperate the 2 wires and tape them up or twist the wires together then tape up. Depending on how the cut off works as to which way it is. I hope this helps.
Regards
FrankC
Powabyke Ltd
MazB
58
Cheers Flecc, think I confused myself also LOL.
Frank I think I will do as you say as I seem to have a motor cut-off on both handlebars so shouldn't be too much of a loss to lose one of em..
Ta for the advice
Maz.
