I can't get it up ... high enough!
Davanti
310
Another numpty query I'm afraid.:eek:
I'm hugely challenged in the vertical plane (I was originally named Shortbotham), but I can just about cock a leg over the seat to get on/off my absolutely brilliant Wisper 905sel. Also, my back isn't as flexible as it once was, so I need to sit more upright than the handlebars currently permit.
I've adjusted the X-tas-Y handlebar by slackening the 4 clamp bolts to obtain the maximum angle and maximum height settings; but it still isn't as upright as I would like.
Para 6.2(D) of the User Manual states that the torque for the "Handlebar stem expander bolt" is "N/A" and para 15.2 states "The 2 bolts securing the adjustable stem to the front fork steerer tube should not be adjusted or slackened in normal use."
So my question is simples: Can I get it (my handlebar) up higher?
Have a lovely day!
Don
Two ways Don. One is to get a stem raiser to give a jump in height, allowing the range of forward angles to start from a higher base. There's two at SJS on this link
Another is to use a set of riser handlebars, but the above is easier.
Davanti
310
Thanks flecc ... (Psst! Will this invalidate my warranty?)
I'm quite sure it won't, David Miall at Wisper would be unlikely to object to a sensible modification like this, which will not affect the function of the steering head.
Davanti
310
Thanks flecc. When I receive the stem raiser, I'll try to figure out how to fit it ... watch this space ... I will return! Thanks again.
David ... any input?
Don
eddieo
Banned
Jul 7, 2008
5,070
Have just ordered this myself......thanks chaps for reminding me!
eddieo
Banned
Jul 7, 2008
5,070
Mine came to day and well what a difference! To think I have ridden this bike for over a year and this is all it needed......now very comfortable
