Hi guys.
This new downhilling bike I'm converting has a front brake lever problem.
It's flapping around and won't return... It does nothing and is loose.
I dismantled it to have a look and can see the cupped location for the rod on the lever to push against. This is solid. Apart from that the aluminium casting is all one piece so I can't dismantle it anymore.
It's as if the piston in the cylinder connected to this cup is stuck and won't return. The lever itself has a spring but I don't think it's that spring that pulls the piston back.
Any ideas where to start?
Thanks.
Thanks.
