Hydraulic brake issue after tyre change
KirstinS
3,224
899
Brighton
Maybe not Ebike specific , please delete or move if unhappy mrs moderator
I am having a nightmare commute home. Ran through some exploded bin debris and punctured both inner tubes . Gutted
Changed tubes (bike upside down)
Afterwards one of my brakes . Rear one has almost no power with the lever going fully depressed. The front is exactly as it was before . Wheels true and spinning freely , no signs of any damage to Caliper or anything
What gives ?! Avid elixir 5 they are if this helps ?
Surely simply inverting a bike cannot led to such severe issues if they need bleeding ?
KirstinS
3,224
899
Brighton
Turning the bike upside down has done something to the fluid either at the caliper end or up at the reservoir, possibly air has got trapped?
Try bleeding.
Thanks , just seems odd, i worry bleeding treats the symptom but doesn’t explain why . Such as an unseen leak
8,533
Inverting a bike is something I never do now with HDB's, due to the exact reason you have found out K.
The one time I did it I was lucky and a few lever pumps and some gentle tapping of the calliper and brake hose managed to remove the air back to the reservoir, alternately use a lacky band or cable tie and leave the lever fully on to see if that helps.
8,533
Not forgetting as pads wear eventually there will be a small air pocket in the reservoir so at some stage it will travel the length of the hose when inverted.
Trevormonty
1,135
564
17
NZ
Quite normal especially if air in brakes. Pumping or leaving over night normally brings it right, air moves back up to reservoir. Nealh trick of keeping brake level squeezed overnight with rubber band worth try.
Long term look at getting them bleed. Kits are cheap and is easy depending on brand. Checkout Youtube first, may decide its a shop job.
