Hub motor help xf07
Hi all, I need to replace my front hub motor on a cyclotricity revolver, having issues using there website so decided to look elsewhere, found an mxus xf07 on ebay, I was curious to find out what the numbers after relate to. My motor reads ZW G36 XF07 1406 0341.
Could anybody tell me the meaning of the last 8 digits as I can't seem to find an exact match. Or is it not relevant.
Thanks in advance
Ant
The numbers will relate to production s/n , date or a combo of both.
Ah ok makes sense thankyou
What is wrong with your current hub ?
It was pretty much seized up, I bought the bike second hand, I think they covered the bike but left the front wheel out‍♂️ was basically filled with rust
As a spare repairs on ebay someone will take delight in trying to resurrect the hub as a working hub again, we have seen it on here before with terrible looking pics.
Also one doesn't have to use the same hub, if it has the nine pin connector any hub will work a the pin layout sequence is the same .
