I mount motors in a aluminium tube ( approx 1cm larger than motor) concentrically, in which are welded bulkheads contained ip68 glands for control cables. Switches are magnetic. Simply on or off. Units have to be disassembled to alter power. ( which was another question)there are no holes to outside...apart from propshaft which has an O ring type stern tube. Bulkheads are to contain water in rear comparment should stern tube fail( which they do) I have 3 compartments. Power. Control and battery. An O ringed lid bolted to front completes unit.. I have also built one using a seadoo dolphin case. ( a pool toy with a 50 w motor) but using a 400 w 24 v cordless drill.
I want to build a 1000w unit...The plastic casing of seadoo wouldn't cope with heat build up...hence usiing alloy tube for current project..
Any input would be appreciated. I,m fine with mechanical side, O rings , glands, stern tubes but power control is another matter...
Also considering building one using an old jet ski impellor, could use direct drive motor on that.( Impellors run at engine speed, props are always geared down)
If interested google " Seabob"...They are about £10 k...( and weigh 28kg for F5 and 35 for F5s...per weight dearer than a Ferrari? Or superyacht.. ( a 1 tonne car would cost 2.8 million to same pricing) .They are awesome tho...again if interested google " Subwing". Definitely most fun you can have at 3 mph..but that needs a boat...capable of 3mph !!!! and a driver willing to sit at 3mph !!! First easy...second way harder..
