Hub Gears
This might seem a bit of a stupid question, I've never really looked into, but can anyone explain how hub gears work?
Diagrams if possible. Thank you
You might enjoy this website - very informative about the different makes and types of hub gears.
James
Being technically challenged. The way I have seen it explained is that on an 8 gear hub 1 & 8 are the same range as on a 27 speed dérailleur and the other 6 are spaced out in between giving a lot more range. Now, not sure if this is totally correct.
The other advantage is if you have to come to a stop on a hill with a hub gear you can select whatever gear you want while stationery, that has to be a good thing! Plus the reliability and lack of maintenance factor.
I dont know how they work though.........
Edited by eddieo
Thanks guys, it was just one of those things that I had never really thought about. The last time I rode a bike with hub gears was about 1977, I should imagine they're of a very high standard nowadays.
You tube is your friend. There is other links on this page showing how they work....a picture tells a thousand words:)
Me too, my Raleigh Hustler had a 3-speed sturmey archer in 1977.
Well spotted Nick! :D
It's amazing how much confusion there is about epicylic operation, even the simple ones in hub motors.
