How to start?
anonymous
138
15
I don't even have a regular commuting bike so far.
What I really want is a bike
- that's easy to fold ie: to fit in my car boot
- has a long range (60 miles?)
And I'm not sure you can get that with a regular prebuilt ebike? I also wouldn't know what bike to buy too...
16,856
it's not very difficult, but you may have to do the conversion yourself.
Start with a Brompton because it's the best folding bike that can easily go in the boot of most cars.
Fit a Q70 wheel. Find a way to mount an HL battery to the head tube.
That's it.
Reactions: anonymous
anonymous
138
15
That's it.
Tbh. I'd probably pay someone to do it, if it means I get a decent quality bike at a decent price
16,856
if you reduce your range to 40 miles, it will be a lot easier because the battery will be 30cm long instead of 36cm. It makes a big difference to the task of fitting the battery to a small bike.
E-bike batteries are typically built with 18650 cells, as packs of 30 cells, 40 cells and 50 cells.
30 cell packs are a bit weedy, 50 cells a bit bulky, 40 cells about the right choice for the Brompton.
With 3500mAH cells, you get 36V * 14AH, good for 40-50 miles with little pedalling.
16,856
their B75 is excellent value for money. You don't need many gears when you have an electric motor.
anonymous
138
15
Thanks. They really are cheap! I guess I'd probably want to go back to a standard bike fairly easily too ie: improve overall fitness too. Is the one I linked to OK?
16,856
they all have the same frame, so it won't make any difference to fitting a kit.
anonymous
138
15
Should I buy this kit? Still not sure about the tyres
16,856
the range is limited by the battery's capacity.
the battery on that kit has 30 cells, eco: 36V * 7.5AH, pro: 36V * 10.5AH.
Brie
11
I was going with the Swytch kit, but was put off by their reported less than helpful attitude if there is a problem amongst other things. Nano in Leamington Spa do a similar kit for Bromptons and regular bikes. I’ve settled on the Woosh XF08C kit for mine.
Benjahmin
2,590
1,746
70
West Wales
It's tempting isn't it, Nice easy conversion? However all that battery weight on the handlebars......I'm not so sure, and you'd definitely want the bigger (heavier) battery.
Also, as mentioned, their customer service has reportedly been ropey at best.
5,786
Big wheels = high top speed and stability
Little wheels = more torque for climbing hills and less stability
For commuting 25 km I know what I would choose. If it has to be folding then you have the Tern Joe or the Montague.
anonymous
138
15
This thing?
anonymous
138
15
Why not the Brompton? Also I'd rather not have a foldable bike but bikes aren't allowed inside the house as per the rental agreement, and I already have a car. I can't really store it anywhere securely otherwise
3,993
Get a van and store your bike in the back of it. That's what I do. My Peugeot Partner does 55mpg, which is loads better than the saloon car I had before and it's nicer to drive.
anonymous
138
15
Get a van and store your bike in the back of it. That's what I do. My Peugeot Larger does 55mpg, which is loads better than the saloon car I had before and it's nicer to drive.
I did actually think of buying a cheap as hell van just to store a bike in it, but then I thought about my insurance... I'd also prefer my car now especially as it gives better mpg than that!
