How to replace Kalkhoff Impulse motor
4bound
172
86
Neston
www.facebook.com
The impulse motor on my Kalkhoff has finally given up - it now has short periods when the pedals turn but there is no drive to the wheels. This can only get worse so it seems I need a new motor.
It so happens that we have another, but rarely used Kalhoff, also with an impulse motor, in the house. So my plan is to use the motor from this second bike to bring the first one back to life.
The question is how? I know lots of people have had problems with this motor over the years, so am wondering if anyone has a guide or indeed just some tips, on how to go about it?
30,836
There were some changes in the Impulse units over time, so best change the motor unit and handlebar unit as a pair to avoid any incompatibilities.
I can't give any other specific advice since I've never changed one.
Reactions: 4bound
4bound
172
86
Neston
www.facebook.com
Hmm, - the broken one is an s-pedelec whereas the new one isn't, so I was hoping to leave the control system unchanged. The units look identical from the outside!
30,836
Ah, not the same model. Well you can only try, you may be lucky with the two compatible enough to work, but I very much doubt it will perform as an S pedelec.
The Panasonic units the Kalkhoffs used initially all looked identical outside, but their circuit boards had various differences internally, according to the bike maker's requirements.
6,722
peter might be able to fix it.
if you want to remove the speed limit from the new motor you will need a dongle.
Reactions: 4bound
