Take one Aldi aluminium water bottle and cut the bottom off with a Dremmel:
10 cells will fit in with the BMS alongside, or you can get 12 cells with the BMS on top. The BMS I used is just too big to fit clat, but I think it might fit if you rounded off the corners.
It needs a charge socket.
The socket was epoxied in, then I had to cut down the top a bit:
before
after
before
after
