How to fit dog trailer to pro rider wayfarer
mand1213
Aug 13, 2023
Hi, I am loving my Pro Rider Wayfarer ebike and want to attach a dog trailer to it but unable to use the attachment on it as a cable is running through the spindle, obviously it must come out somehow so your able to change the tyre but I didn't want to damage anything so hoping someone on here may be able to help.
Kind regards
Amanda
3,380
You need to show us some photos of your bike axle and the trailer hitch. It's normally a case of drilling out the hole in the hitch to 12.5mm to go over the axle, disconnect the motor cable, remove the axle nut, thread on the hitch, put the nut back on tight, then reconnect the motor cable.
Does your Wayfarer have a connector on the cable about 8" from the motor? If not, you have to disconnect the cable all the way from the controller.
Usually one would have the tow hitch on the opposite side to the motor cable, my carry freedome allows the tow arm to fit on either side.
