No, no magnetic bottle holder. No any magnets where I keep the bike. This error 510 was a random error. After rebooting the bike, it was OK few days without any error. But actually the reboot doesn't help anymore.It's caused by magnetism. Did you fit a magnetic bottle holder or anything like that? Do you have magnet strap holders on your shoes or any magnets where you keep the bike.
Your symptoms are exactly what other people describe when they have a magnetic field near the motor. Magnetic fields can also be caused by electrical devices as well. Do you have any thing like that where you keep the bike? Some people are blaming the magnetic loops burried in the road that operate traffic lights. Did you used to get the problem in the same places?The only magnet near is the magnet of the speed sensor attached to the spike of the rear wheel.
In my case this error 510 is now everywhere, does not matter if I'm in the, city, in the home or, even in the forest. I checked with my phone with magnetic field measuring app. I do detect some magnetic field near the speed sensor magnet ( that is normal), near the battery and near the motor. I saw other type of electrical motors used in rear wheel - there is coil wirings and permanent magnets inside the motor, and hall sensors to detect motor phase and spinning. I never disassembled a Bosch motor to see if there are magnets inside.Your symptoms are exactly what other people describe when they have a magnetic field near the motor. Magnetic fields can also be caused by electrical devices as well. Do you have any thing like that where you keep the bike? Some people are blaming the magnetic loops burried in the road that operate traffic lights. Did you used to get the problem in the same places?
Thank you for the information.Error code 510 - Bosch Performance Line CX
My experience may be of interest, given it is quite bizarre! My bike is Kalkoff 5B Move bought in October 2020. I needed to tighten the steering head bearing but accidentally snapped off the end of my 1.5mm Allen key in the M3 grub screw that retains the two-part adjustable spacer directly...www.pedelecs.co.uk
I removed already the motor cover and the belt gear. The next step is to remove all entire motor, or the right side of the motor to open it. But to remove this side of the motor I need a special extraction tool. Or I risk to damage it if trying to open with a flat screwdriver.If it were me, and having read the linked post, I would be finding myself a good quality compass and start testing the various components on the bike - if necessary taking them off one by one to test them....particularly the chainrings. Hard to tell with the components on the bike if it's a magnetic field internal to the motor or something next to the motor.
OK. Thank you. I will tryeBike Motor Repairs & Servicing - Homepage
eBike Motor Parts Repairs & Servicing, (formally, Performance Line Bearings) has become the “go to place” for all your e-Bike motor repairs...www.ebikemotorcentre.com
if you cant find any solution then speak to peter or he can px the motor you have for a new one if required tho i have never had this problem on my bike in 10 years.
No. Can you explain it to me please? Soundwave keeps shoing his, but all I see are cog-wheels and some electronics.You do realise the motor is full of permanent magnets and magnetic fields?
It affects all versions. There was a new firmware that was supposed to fix it sone time in 2021. If you have older firmware, it might be worth getting it updated, but there are many causes of the problem, so don't count on it.Another useful information is to know, what Bosch motors are vulnerable to this error 510.
Mine is Gen 2 motor, performance Line CX, BDU250P CX (0275007037)
If someone has another generation and the same problem, it would be nice to share that information.
