How many torque arms
5,786
My new build looks to be my current rear motor kit in a bigger, more comfortable 700C frame. I really wanted to put a GSM CD in there but finances being what they are... I thought about running a web campaign but "poor underpaid bloke living in a wonderful part of the world needs funds for sexy e-bike build" does not seem such a great idea...
So how many torque arms does my rear motor need in an aluminium frame?
If one which side do I put it on?
Cheers
Tony
trex
7,703
2,671
I reckon you only need torque arms if for motor with 180mm diameter or above. Use a pair, sung fit is important.
8,775
My Oxydrive/Bafang CST is on 700C Boardman and I have a home made one piece arm on the disc side albeit the motor is 250w, a bigger watt motor may be better with two to handle the extra torque/power.
5,786
Thanks for confirming my thoughts guys. I'll give it a whack with the supplied washers and nice and tight on the nuts. I think that if there is no play i.e. careful on the filing of the dropouts to fit the axle it looks solid enough to take 250 W.
Fordulike
3,802
1,538
I don't want to cast doubt in your mind, but for something that costs a few euros, I would fit at least one torque arm on a low powered set-up.
Probably easiest on the non freewheel/cassette side.
It would lessen any risk of the axle working the nut loose. Even on a low powered motor, there's still a fair amount of rotational force trying to spin that axle in the dropout.
8,775
I have to be in agreeance for safety sake and to prevent any future incidents then 1 is needed on the rear and 2 on a front build with ali forks.
gstanley
11
7
31
Lincs
Sorry to drag up an older thread again, but my left axle nut keeps working itself loose after only a mile, would a torque arm stop this do you think? I have one being delivered this week
Reactions: LeighPing
Fordulike
3,802
1,538
Most likely yes. The torque arm will help to prevent the slight axle movement that occurs when the drop-out/axle isn't a totally snug fit. This loosens the nut as time goes on.
You've got nothing to lose and everything to gain by fitting a torque arm. Last thing you want is that wheel to pop out while you are riding :eek:
Is it a direct drive motor with regen?
A torque are would probably help. So would a spring washer.
