Hi
I got the replacement charger from my supplier earlier this week and I've now bench tested my setup - everything working as it should, thankfully.
I took advantage of the long weekend in Ireland to shorten the motor cable and that's done and tested with only the final insulation to add.
So to my question, the display showed a speed of 42 km/h on the bench. Obviously that's not correct as I have a 20" wheel and the controller is probably set for 28" or something - I haven't changed this yet.
What I can't understand is if the controller thinks the bike is doing 42 km/h, why wasn't the power cut at 25 km/h? That's what I was expecting to be honest.
Also, how do power levels work? I have five. Suppose on level three, should I get 60% power up to 25 km/h or full power up to around 15 km/h? From what I can see, it's a standard sine wave controller.
At least everything looks good now, with the tricky bits done. Looking forward to wiring everything up neatly and trying it for real.
TIA
TIA
