How do you ride your ebike
enndee
53
Have been riding my first ebike this last week and find that I tend to cruise a couple of mph above the cut off point but that when going up a hill I can end up hovering around the cut off which seems to cause more of a strain. To get around that I either push on faster or let it slow to within the limit.
So I was wondering if people tend to try to keep within the max assisted speed or whether they only use it as a starting off boost?
Your bike uses a speed-control controller, so that the different PAS levels are speed targets that the controller tries to maintain. The greater the difference between the target speed and your actual speed when below the target speed, the more power is given by the controller in an attempt to get to the target speed. This means that you get a sort of automatic power control for climbing hills. The slower you go, the more power you get. Some other bikes don't work like that, like Bosch, Kalkhoff, Panasonic, etc.
Alan Quay
2,351
1,076
Devon
I use mine differently, depending on situation.
If I'm going to a meeting on a warm day wearing a shirt, I will be letting the bike do most of the work. I'll pedal, but not put in a lot of effort so that I arrive looking like the chauffeur dropped me at the front door.
If I'm coming home, I'll turn the throttle full on, and pedal as hard as I dare, so that when I arrive home I'll be sweating like a Disk Jockey under cross examination.
awol
1,216
374
I have PAS on low to simply help get the bike moving from a standstill and when moving I do the work pedalling but keep the throttle just a smidge over my speed so I'm not out of breath. This makes pedalling really easier, gives me more (pedalling)speed and cancels out headwinds.
pdarnett
599
140
Bradford
www.mybigdaydj.co.uk
I usually ride with a low level of assist, but blip the throttle on setting off to bring me up to speed then pedal to maintain that speed.
enndee
53
My bike has the usual 5 levels of assist. I thought they just set a target speed and once achieved they cut off completely, or do they continue at a lower rate until the 15.5mph cut off?
30,843
Some systems phase down the power as it approaches the assist limit, and this is a requirement of EU law on pedelecs. However, that law does not specify the point at which phase down starts, so some systems are more abrupt than others.
The most severe phase down law is the Japanese one, they require the phase down to start at 15 kph (9.4mph) with power terminating at 25kph (15.6mph). That is so gradual it's impossible to determine exactly when the power actually disappears!
The amount of power you get depends on how close you are to the target speed. It reduces as you approach it from below. You get no power above it. The slower you go, the more power you get up to the controller's maximum.
EddiePJ
4,632
4,013
Crowborough, East Sussex
www.facebook.com
That is another aspect of the BH hub drive that I like. In an off road situation you can sort of cheat the system into running on for a few seconds almost above cut off speed after you have stopped pedalling. It comes in very handy when hitting deep ruts that you would otherwise not be able to pedal properly along. I'm pretty sure the BH cuts out on the wrong side of the required limit. :)
