Help! Hopper Replacement Ignition Key
KTANDERSON1969
Hi, I wonder if you can help.
I've just purchased this bike from a local, reputable auction house (nit stolen), but I've discovered it has no keys.
Would anyone be kind and able enough to help me source replacements please, or suggest a solution if there is one?
Thanks very much.
4794547946
2,756
If you don't know the key number it will be very difficult to find a replacement.
To unlock you could try a set of jiggler keys (random example https://uklockpickers.co.uk/keys/jiggler-keys.html) or drilling out the centre of the lock. I've never tried either, but apparently not too difficult.
However, as the key appears to do ignition as well you are then going to have to try to wire some alternative,
and have some alternative for holding the battery firmly in place.
It may be worth trying to contact the sellers via the auction house.
Reactions: KTANDERSON1969
KTANDERSON1969
Thanks for your kind reply. I thought it may not be as straightforward as hoped! Rarely is! I'll try the jiggler keys and hopefully one will work. Fingers crossed!
Andy-Mat
2,214
562
78
Thanks very much.
View attachment 47945View attachment 47946
Did you check if the previous owner simply forgot to give them to you?
It does not appear to be a lock that I have seen, but careful use of a thin router bit, cutting equally either end of the slit, should "let out" all the tiny bits, and then you can switch it on and off with a large flat bladed screwdriver.....
Maybe then a lock smith can offer a replacement.
What a shame....
How about demanding your money back?
regards
Andy
KTANDERSON1969
What a shame....
regards
Andy
Hi Andy, thanks for your really helpful reply.
Unfortunately, the Auction House have adopted the 'tough, sold as seen, nothing we can do' approach. I suppose I should have asked if keys were supplied, but hey-ho, the benefit of hindsight!
I'll give your suggessome consideration, thanks. I've ordered a set of 'jiggler keys' which hopefully will at least unlock the unit so I can take it to a locksmith for advice.
I'll let you know how I got on. If I DO!!
StuartsProjects
1,786
1,009
I was given 3 batteries, the down tube type, that are fitted with locks like that.
One battery, with a key, was toast, a Lithium Polymer that had swelled and would not come out of the metal case.
The second battery looked OK, all groups in reasonable balance but had a mangled lock, so I should be able to swap the locks around.
48019
48018
StuartsProjects
1,786
1,009
Careful use of a thin router bit, cutting equally either end of the slit, should "let out" all the tiny bits, and then you can switch it on and off with a large flat bladed screwdriver.....
Is there a 'one size fits all' type of router bit that would be suitable for such lock surgery ?
KTANDERSON1969
Thanks for your kind d help. Really appreciate it.
KTANDERSON1969
Andy-Mat
2,214
562
78
Let us all know if you still need help, and I can probably help further if you need the Dremel Router idea ro work for you.
regards
Andy
Andy-Mat
2,214
562
78
The router bits I am talking about are about 4mm thick, and very hard, they can cut through steel and other metals. They are best used slowly (pressure wise), at around 20,000 RPM (Dremel or similar), and I have yet to find any lock that can withstand them!
I could not find an exact version for you on ebay UK, but I am willing to buy you say two, on the German web site, and send them on. You cannot buy there as you have to be a licensed Lock smith in Germany to buy such articles.
If you wish, I can make a close up picture, to allow you to search in the UK for them, they will probably cost around 10 UK Pounds each, but anything cheaper will not do the job, though as the version I haven simply do not wear out, I haven't bought any for years......they may be cheaper nowadays.
Do wear safety googles, as some of the tiny lock parts will exit the work area at the speed of sound!!!
I have used them (the exact same ones!) since 2007, when i worked for a company that did lock smithing. I joined to learn the "mechanics", but it was morally reprehensible, so I left after 7 months.
regards
Andy
StuartsProjects
1,786
1,009
A picture would be helpful.
I have a mains powered Proxxon, its a bit more power than a Dremel. Only goes up to 3.5mm though.
Andy-Mat
2,214
562
78
Mine (which have been used many times, with no sign of wear), are 3mm x 6cm.They munch through any cylinder quite rapidly with only light pressure from me.
regards
Andy
