nope my bike guy just had a look and said its done and not to try to use it esp the speed i can go.I’m amazed you asked really
As you new the answer before you asked
these are the new ones of what i have so not cheap.At least you use cheap wheels so it will not break the bank to get a replacement!
If that is the rear, I would inspect the front as well to be on the safe side.
if i change make of rims ill also have to buy a xd driver for the rear so another 100 quid on top.I seem to recall KTM Col being rather negative about the quality of Crank Bros wheels and products.
its not the wheels it is the sealant that has caused the damage as there fine bar being eaten from the inside outVery lucky not to get a high speed blow out front puncture.
Unless you really like the bling value I might be looking elsewhere for my next set of wheels
