Hola from Spain!!
briotone
Mar 1, 2012
Hi people,
I am English, originally from London but now live in southern Spain, mainly for health reasons but having lived here for over eight years, my wife and I have grown to love the rugged grandeur of the country, the mostly decent weather (we don´t get snow at all) and the people.
The biggest plus is, there are very few gradients, certainly no hills.
Unfortunately, I have a chest complaint that necessitates the electric assist.
I have a Giant beach bike fitted with a Crystalyte rear wheel motor, with Hall sensors.
Had the bike for a few years now. Originally, it was fitted with a LiFePO4 chinese battery, the size and weight of a lorry, it seemed!! However, it died after one month, so I went with four SLA batteries, which were good but so heavy @ 40lbs!!
I currently have a new LiFePO4 48 volt, 12 amp. battery, fitted into a small Crystalyte soft zip pack, that weighs 10 lbs. Shangrila!! Technology has moved on!!
I am in the process of fitting a Stand alone Cycle Analyser unit, that requires a shunt (supplied) but need to solder the connectors of an Anderson plug to fit between the battery and the controller, so need to sharpen my skills in that area.
If all this sound like I am a guru, forget it!! I have learned what I´ve learned, the hard way, believe me!!
Anyway, it´s good to be a member of the Forum and look forward to relating experiences, good and bad.
30,835
A warm welcome to the forum Briatone, I look forward to your contributions while being jealous of your cycling weather!
C
Cyclezee
Welcome Briotone,
As you live in southern Spain, you must know Funkylyn?
funkylyn
3,172
27
South Shields, Tyne & Wear
Welcome to the forum Briotone !
You will find lots to entertain and inform you on this forum.
Whereabouts in spain are you ?
Obviously not near where I was.....Alora, inland of malaga...... if you have no hills !
Of course weather wise you have it great this time of year.....but not so good trying to cycle
in the blistering heat of summer !!
Lynda :)
briotone
Mar 1, 2012
Lynda :)
Hi Funkylyn,
no, we are way down the country, in a lovely place called Santiago de la Ribera, which is a suburb of San Javier.
We are literally four minutes from the sea on the bicycle tracks. It is called the Mar Menor (sea minor) but is in fact a huge lagoon and some 10 degrees warmer than the Med!!
