Hi All,
Does anybody on here have the experience of replacing a damaged wiring harness from a direct drive brushless rear hub motor? Is it as simple as just removing the motor cover and cutting back the wires as close as possible or do you need that special case clamping tool that separates the whole magnet from the motor casing in order to get to the wires, any good tips??? Cheers!
MS.
MS.
