Hill Climb Boost Battery for the your Torq
The T bike (Torq Radical) that I've just announced uses a technically simple NiMh battery modification that makes a substantial contribution to the greatly improved hill climbing. Much of the benefit will be given to any Torq using that battery, so I've posted details on how to achieve that in three different ways. This is not for the users of Li-ion batteries, strictly only for those with the NiMh battery.
If you're interested, read through the article first to understand what's involved. Here's the link.
coops
1,225
Manchester U.K.
Thank you for the very detailed instructions flecc, I will certainly be looking into the feasibility of doing this for the performance boost it gives the Torq.
I'll have to first locate a chippie a sufficient distance from me too, of course :D.
Stuart.
HarryB
1,318
London
I'm not far too behind Peter, three eZee Li batteries to date, with two chargers.
But one is due for conversion to a T Radical NiMh type, to bring me to a pair of those.
The lithium chargers charge the NiMh batteries as well, but it's essential to stop the charge before it exceeds 42 volts, read when off charge.
Flecc,
A couple of questions. Are you still going to convert one of your lithium batteries to NiMH and is it possible to modify the lithium charger to cut off when they get to the right voltage? I wouldn't mind going over to NiMH when my battery finally dies however I have couple of chargers (one for work and one for home) and the cost of replacing them both would put me off.
Yes, converting the older Li-ion is my intention Harry, only delayed because the Q bike can still make efficient use of it even though it was previously dud in Quando and Torq. Come winter's colder weather though and it will be finished if not before, so that will be a good time. Also, the current silliness over the nickel "shortage" and NiMh cell prices will be over by then and larger cells might be here.
I doubt if it's possible to modify the charger, even though it's the same style from the same manufacturer. The problem is the Li-ion one cuts at a voltage rise signal, probably from the Li-ion battery's own electronics. NiMh chargers have cutout circuits operated by a voltage passed by a thermistor in the battery, that operating on the temperature rise just before the end of charging. That low voltage for the thermistor is generated by the NiMh charger, that circuit not part of the Li-ion charger's board.
I've also got two Li-ion chargers so I sympathise. If I do discover a way I'll definitely let you know though.
Ian has converted an eZee Li-ion to NiMh by the way.
HarryB
1,318
London
I thought he already had gone down the NiMH route thus saving £100 and not having to replace batteries after 8 months. Do you know how he went about it, I have done a search but not come up with anything?
I only know he used the usual button end cells Harry, and bound them into the columns for the case. The trouble he had was that they are longer than the flat ended original so he had quite a lot of difficulty packing the longer columns into the case. I don't know what he did about thermistor or fuse.
I know what thermistor it should be though, it's a Semitec AT-4, part number: 103AT4 Shape 2. If not available, 103AT4 Shape 1 will also work. The main specification is R = 10k, B = 3435.
Semitec UK. Phone: 01606 871680, NTC Thermistors
If there's any problem, a wide tolerance replacement is a Murata component from Radiospares, part number 188-5256, R = 10k, B= 3380
Ian has just left on holiday before the weekend, but he'll be back in a couple of weeks so you could check for more details then.
Flecc,
Harry, further reply. I've been trying out the Li-ion chargers on the Radical's NiMh battery, and both Li-ion chargers cut out at just over 42 volts, sensed by the voltage it seems. That's too low for the 33 cell Radical battery, but actually a good enough full charge level for the standard 30 cell NiMh battery, being just over 1.4 volts per cell.
If that also holds good for a standard eZee NiMh battery, and I think it will, they will be ok. I can't guarantee it of course, but perhaps another member who has both charger types and an NiMh battery would check by using the Li-ion on it and checking the battery voltage at end of charge. When Ian returns from holiday he might do that for you since he has the chargers and a standard NiMh battery.
Ian
1,333
Leicester LE4, UK.
Hi Harry,
I've got back and just caught up with this thread.
I've always favoured NiMh batteries and did buy an additional ezee one about 3 months ago, however I then bought a secondhand Sprint with a dud Li-Mg battery and as I had an almost complete set of NiMh D cells salvaged from an earlier bike it made sense to use them to re-cell it.
The cells I had were in a side by side arrangement with spot welded nickel strips joining them. Unfortunately the only way 30 cells would fit in the Ezee case was to arrange them in 6 columns of 5 cells which is the arrangement used in Ezees own NiMh batteries. After various experimental arrangements I came to the conclusion the only way they would fit would be to tear off the joining strips and rely on pressure for a good contact. I was 2 cells short of a complete set and the deficiency was made up with 2 pipped cells purchased on ebay. The battery has been working reliably for while now, its capacity is noticeably less, and the weight a few grams higher than the original Ezee batteries but I'm sure this due to the lower capacity, poorer quality salvaged cells used.
This is a diagram I made at the time, hope it helps. Note, it's not the same as the original Ezee build, they use what looks like shrink tube to hold the cells in columns, looking rather like sticks of dynamite, could explain why the bike is so fast.:D
Safety Note: It is very important that everything is well insulated with materials that can resist the temperatures reached, these cells can put out enough current to easily start a fire, particular care should be taken to avoid all possibility of a short between adjacent cell casings.
Ian
1,333
Leicester LE4, UK.
Really Steep Hills
I Could have done with some of that extra climbing ability on the hill shown below. Funnily enough while walking the Torq up that quarter mile of 1 in 3 I met a postman coasting down on his heavyweight Royal Mail issue Pashley complete with panniers front and rear and a large handlebar bag. As the only other way out of the valley was up a similar hill on the other side I'm wondering how he did get out, perhaps the van collected him later.
Some of those Pashley riders get very strong Ian. I remember one day riding from the foot of local steep Corkscrew Hill at West Wickham having a Postie join from a side road riding a heavily loaded Pashley and cycling up there no trouble, sitting on the saddle. I only just managed to catch up with him riding the Lafree Twist electric bike.
Mind you, he was looking enviously at the Twist as we rode together along the flat at the top chatting about the bikes.
Ian
1,333
Leicester LE4, UK.
I suppose anyone doing a post round on a bike in that terrain is going to get very strong, mind you when they get electric bikes things might not be any easier, I doubt they'll get bikes that'll climb 1 in 3, and if they're pedelecs they'll have to pushed without any assistance, and anything they're likely to get will make the Pashleys seem lightweight.
Yes, I'd thought of that too Ian, since I think they're certain to choose the German post bike as a play safe choice, and that will be a pedelec of course. I don't know what it weighs, but it's massively built with a huge wheeled stand and front and rear substantial carriers as well as the electric system, so I think it will probably be right up to the 40 kilo limit. Maybe it's motor is the geared down 11.5 mph version though, and that climbs most hills. Not 1 in 3 though, but I understand the Royal Mail have been telling customers who have what is termed "difficult access" that they must collect their mail in future, so they have a cop out!
HarryB
1,318
London
Thanks Ian for the information about re-celling a torq battery. Not sure it is worth it unless you have the cells to re-use as it seems to be cheaper to buy a ready made battery from 50 cycles. I am running the Torq restricted at the moment as unrestricted the range is fairly hopeless, barely reaching 10 miles. Restricted it will go 20 miles with plenty of juice left so hopefully the battery has many more months or maybe a year of life left. However the torq is pretty gutless when restricted but something I will have to get used to.
coops
1,225
Manchester U.K.
Thanks for the NiMH recelling information Ian, very useful :).
To HarryB:
If you get 20miles+ restricted, then with careful throttle & speed limiting I think you could still get at least, say, 2/3 of that range when derestricted, if thats any help? :)
Stuart.
Ian
1,333
Leicester LE4, UK.
The replacement NiMh batteries from 50cycles are good value when available, and the cells used seem of good quality and suitable for the purpose. Any cost saving with the DIY approach would be minimal and it would be difficult to guarantee the cell quality.
My next re-celling project will probably be a lightweight "get you home" battery with C size cells of about 5Ah, if I can find them at the right price. It seems pointless lugging a spare 5.5kg battery around when it only gets used for the last couple of miles.
HarryB
1,318
London
Stuart.
Thanks Stuart for the advice.
Yes I have tried to limit how much I use the throttle, all I can say is it never works out for me and I run out of juice on the long but gentle hill up to my house. Restricted I cycle at about 17mph and therefore barely use any power. Unrestricted even at that speed it is difficult to know how much power you are using. I have tried to ride without the meter going into the yellow (and using the noise of the motor) as a guide but in the end it is too much hassle so I am restricted and will put up with the lousy hill climbing.
coops
1,225
Manchester U.K.
Ah, I see HarryB :) thats how you get the range when restricted then :rolleyes: ok, I see what you mean now and why unrestricted wouldn't work... sounds like you do well to squeeze 20+miles out of your battery as it is :D.
NiMH here we come? :rolleyes: :)
Stuart.
aaannndddyyy
304
9
64
Norwich Norfolk
Radical Battery
Hi just finished my upgrade of fleccs radical battery using his third idea as the batteries will not fit the rack if altered here are a couple of pics of my bike with a Heinemann front hub and a powerbyke rear hub fitted.
On the Heinzmann I was able to add 4 extra NiCad 4.5 amp cells which I got off EBay for 1.50 each to the 36v 5amp NiCad battery pack, on a full charge the pack reads 47.8v, on the Powarbyke I added 6 extra 8 amp nimh batteries (I managed to get from a friend for doing a little gardening) on a full charge reads 51.4v both controllers seem to be able to take the extra power with no apparent side effect, being a flatlander (no steep hills to worry about) there has been no heating problems as yet. with the 54-44-34 crank set I am able to reach 19 mph with the Heinemann with good toque which is the maximum the motor will give, shutting the Heinemann down then adding the Powerbyke I am able to get 25mph on the strait :D , using both throttles to pull away there is excellent acceleration, the weight of the bike with both batteries comes in at 38kg which is heavy but the extra power more than makes up for the weight, the range has also improved giving around 40 miles total which is 5 miles more than I was getting before adding the extra batteries. I have been keeping a close eye on the temperature and voltage well charging these batteries as the chargers are for a 36v setup, so far there have been no problems.
Neat job aaannndddyyy, well done. You're the first to do this, and I'm glad it worked out well for you.
As you say, it makes quite a startling difference to the performance, acceleration, hill climbing and speed. With the four and six cells your controllers cope with it's even better. The extra range comes from the lower stress on the battery resulting from the extra power.
