Hidden wire brake sensors and CAv3
Tangsoo
51
58
I've got one of the above and know where the connectors go for the normal two wire brake switches but are the three wire HWBS compatible and if so how so? Controller's one of EM3EV's kit
You just treat them like a normal brake switch except that you connect the red wire to a 5v source, which you can get from the CA or the controller. You can connect the brake sensor to the CA or the controller.
