Hibernating battery
chrisbach
11
Having been unable to ride my Wisper for a while I kept the battery (535) topped every few weeks up as per the instructions. But it was charged, green light, and not powering anything when I next tried to use it. This is being sorted .
How do you keep these batteries from dying please?
chrisbach
11
Oops 575
chrisbach
11
Hi David.
The battery would be 2 yrs old at the end of this year, and being replaced (I hope) under warranty.
I am just checking to try and stop it happening again. The charger was on green and the battery was on 36.3. I was charging it often. No life in battery. It is on its way to you.
Is it the correct procedure to put 'charge battery' in my calendar for the first of every month? What if the light is green when I start to charge? Do I need to check with a multimeter?
I, obviously, need instructions lol.
Chris.
Wisper Bikes
6,332
2,292
70
Sevenoaks Kent
Hi David.
Chris.
Hi Chris,
We will of course replace under warranty if we can’t fix it.
Its best to charge it every couple of months, but as I mentioned earlier it’s vital that the battery is never left fully discharged. The best practice is to charge the battery after every use if possible.
The battery may simply have a small fault.
All the best, David
