hi all first poster needs help
Mark Lovell
A, A
hi all im a new boy here and am looking for a bit of info i have an old powerbike the one with drum at back and controller on handlebars a resister has burnt out and i cant fing a circuit diag or the colored code of the resister and really need it going asap as work is a pain walking lol
neptune
1,743
353
Boston lincs
It is difficult to offer help here, unless someone has the same controller. Perhaps it would help if you posted some photographs.
morphix
2,163
119
Worcestershire
www.cyclecharge.org.uk
Is that company still trading? Maybe they could help you out for a circuit diagram or even offer a cheap replacement board? Controllers are fairly cheap to replace so it might not be worth repairing it unless you can't get a replacement of course..
neptune
1,743
353
Boston lincs
Another possibility is to buy a cheap controller from ebay . I believe your bike has a brushed motor, as opposed to brushless. you can confirm this , as if it it is a brushed motor it will have only 2 wires entering the hub.
Mark Lovell
A, A
hi thanks for the reply i have tryd the maker but they say they cant give me this info bit annoying as if it was a tv i can get the diag very easy lol typical i will looking to getting a cheap one from ebay if i cant sort this one
30,567
Mark, if you ring Frank Curran of Powabyke directly as suggested above, instead of just "the company", you may well find him more helpful.
bweebar
12
Cwmbran
Brown, Black, Black, Gold, Brown which is 10ohms 1%, it also measures 10ohms in-circuit and feeds the input to the 7812 voltage regulator.
You'll have to use a fairly powerful soldering iron as the board is double sided and there's a lot of copper which will suck the heat right out of the tip, a 15watt hobby iron isn't going to do the job.
If the bike doesn't go after you replace it, the first thing to check is that the voltage regulator is outputting 12volts (from left to right in my picture pin 1 is the input, pin 2 is ground, pin 3 is 12volts out).
Mark Lovell
A, A
you are a ledg m8t you wouldnt belive how hard it was getting that info very happy i have a solder station as always tinkering so invested thanks again for your time and info m8t
