A stiff motor wheel is most likely due to shorted motor phase wires or controller FETs. If you unplug the motor from the controller, does the motor become easier to turn?
HI, HAVE UNPLUGGED CABLE, soz , and rear wheel still very stiff and tight in one particular spot, once unplugged the motor problem warning light also comes on, tried some elect clean spray in connector but no luck. also if brakes are pulled on get the braking indicator light as well, from user manual ... which just says in trouble shooting ... contact supplier !!
LCD DISPLAY GUIDE
Battery Power Level (In Percentage) Battery Power Level (Icon)
Button +
Current speed
Speed level
Button M
Button -
BUTTON GUIDE
Gear 0: Riding without assistance.
Gear 1: Lowest speed, max: 10 Km/h
Gear 2: Mid-level speed, max: 15 Km/h
Gear 3: Highest speed, max: 25 Km/h
LED light indicator
Brake Indicator
Throttle problem Indicator
Motor problem Indicator
Controller problem Indicator
Shifting display; current mileage / total mileage
/ run time
