Hi All,
I have just finished building a recumbent trike based loosely on the Atomic Zombie Warrior.
I've laced a 201rpm Bafang SWXH into a 26" rim and am using a 20A (max) KT controller powered by a homemade 14S 30Q battery.
It all works, and pulls nicely from a stop, with the display showing 1000W, but as the speed approaches 10MPH the power drops right off. At 10MPH the display shows 300W, at 12MPH at shows about 150w.
I have set the speed limit to it's max value and even tried setting the wheel diameter to 18" instead of 26" in case there is another speed limit that i'm hitting somewhere, but the behaviour is exactly the same. This happens on all PAS modes and I've tried connecting a throttle as well, but this doesn't change anything.
By my calculations the 201rpm SWXH should be good for 18-19mph on a 14s battery so I'm not looking for a huge top speed, but for it to pull well up to 15MPH
I'd like to keep this build legal and will be reducing limits and removing the throttle once I have (hopefully) resolved this problem
Can anyone help with what I've done wrong.
