Hi, new here!
Recently installed a new e-bike front motor kit from Yose Power. I've set it up so I'm only using the pedal assist. Everything seems to be set up working great. The controller is integrated into the battery base. The LCD is a KD21C display. The front motor is 250w.
I'm a bit confused about the pedal assist settings so was hoping someone could clear my thoughts up! (And maybe help understand if I could get what I want...)
I've left the settings mostly default, they're all fine. I've changed the assist setting to 0-3. I like quickly being able to change from no assist for tight careful manoeuvring, to some assist on the flat, to 2 for the up hills. Haven't even needed the highest setting, maybe when I feel super lazy.
In changing the assist you can alter the ratios, between 0-100, and an AC/or UC at the max whatever that means. My assumption was this is a % of assist provided up to 25kph. But this isn't what I feel when I'm riding so I'm a bit confused by how these ratios work.
For example, (and my assumption was), if I had level 1 = 20, I would get 50 watts of power up to 25kph, if level 2 = 60, I would get 150 watts up to 25kph.
In practice I have left the settings for 0-3 the same as the level 2/4/5 on the 0-5 setting. So level 1 ratio = 50, and level 2 ratio = 75, and level 3 ratio = 95. This seems fine as it's a copy paste of what felt most useful on the 0-5 setting assist.
But what I feel when I'm riding with the 0-3 assist levels setup as above, (and have the watt setting on the LCD to follow the output), is that on level 1 assist the assist is strong up to about 16kph and then tails off, this is fine as I can manage close to 25kph on my own steam thereafter. At higher end of that speed the display is showing 0 watts, but it feels like there is some assist to ~20kph. On level 2 assist it gives loads of assist up to 25kph, great for going up hills etc. Each time the assist kicks in strong, it says it's providing up to ~200 watts on the display. If I soft pedal in assist level 1, it will output 200 watts and then drag me along at ~16kph.
I guess my question is, is this normal for Pedal assist to function like this? Or is there a way of setting it to provide what I what, i.e. 50 watts on a lower setting, and 150 watts on a higher setting? Is it maybe some weird controller? Is the Assist ratio, a ratio of speed, not power output of the motor?
Sorry for so many rambling questions! I'm a bit confused. All in all I'm happy, and if this is just how it works, I can live with the quirks of that. It basically does what I intended it to do. And I hope that was all clear!
NB having written this all out, I've just realised the assist ratio maybe of the speed given a 32kph max. I could test that out, as then level 3 at 95 should assist me to ~30kph. I have the speed limit set at 25kph, but I could see if that theory works. But again, I don't understand by it isn't a ratio of power, unless the display lies!
