Help with pas settings
appaddy
Gloucester
Hi all,
Just got a new kunteng lcd1 dashboard but not convinced the pas settings are correct. All connectors are tightly closed but I have now power to the motor. This is from both the twist throttle and pas sensor (which is lit up when peddling). My kit was from panda e bikes and is a 250W 36V 10amp battery. Have had to adjust pas 5 from 12 to 0 already(after tadvice) to get the battery power to show.
Hope someone can help
Thanks in advance
Wheel-E
97
27
Brighton
Can you retrieve the settings from your old display? What was your old display and does your bike still work if you plug that in?
8,593
You need to check that the lcd wiring sequence match's on the connectors there are 5 wires and needs colour to colour to match.
In most cases, but not always. I've had to go through all 36 combinations a couple of times, though that's unlikely to be his problem. you can tell when the sequence is wrong because you get a click or jump from the motor when all the wires are connected properly. You also get a jump or click when you have a bad or no connection on a wire, so need to check that first.
For testing, disconnect the PAS and brakes to get it working with the throttle first. There's a setting to enable the throttle P4=0
8,593
Just a thought as you have pas led lit, if you have brake sensor/s disconnect them and then try pas and throttle.
