Help with KT CONTROLLER failed PAS & Throttle
SurRonny
19
I'm confused & need some help -
My throttle & PAS has stopped working, LCD red wire line is getting 53.1 volts from the controller which I thought should only be getting 5V ? LCD IS WORKING but not detecting input from pas or THROTTLE
Throttle has continuity from source into controller on all 3 lines red white black ( I have opened controller )
Could it be possible that the voltage regulator inside the controller has failed.
PAS THROTTLE & LCD should all have 5V I know.
It's a KT CONTROLLER.
it's all opened up so let me know what you guys think.
Thank you
nathan
