thanks for your response I appreciate it!Blue - this is removable, but will secure. Red is more permanent
I installed a 250w on a 73mm bottom bracket and got both locknuts onto the bottom bracket without an issue, so you might be lucky. I had to find two longer hex nuts (20mm I think) to secure the triangle and I had to cut one of them down a little, but managed without too much difficulty. Fingers crossed for you! Good luck.Hi I’m looking to install the Bbs02b 750w with a 73mm bracket. I’m aware only one of the locknuts can be installed. What Loctite should i use to ensure it doesn’t fall off? Thank you!
thanks for you response. Hopefully I get the same luck as you with the locknuts! I ended up purchasing the Lekkie bling ring just incase I come across any chain line issues. I also purchased the m6x20mm bolts with a 5mm spacer.I installed a 250w on a 73mm bottom bracket and got both locknuts onto the bottom bracket without an issue, so you might be lucky. I had to find two longer hex nuts (20mm I think) to secure the triangle and I had to cut one of them down a little, but managed without too much difficulty. Fingers crossed for you! Good luck.
