Hi everyone and a merry Christmas to all. Now I am new to forums as I have never needed them so please be patient with me.
Now I am hoping that someone may be able to answer some questions for me.
I was given a FreeGo hawk electric bike last week due to it having a fault. Now I have tested the battery pack which is 36v and after fully charging it and letting it settle for 48 hours the multimeter reads 41.54volts. Now I did find that the pedal assist sensor was pressed up to the magnet disk so once I moved it to 3-5mm from the magnet disk the sensor kind of worked but only for about 4 miles. Now it’s starting to stutter. I did follow a tutorial on YouTube for diagnosing faulty controllers And after testing the phase wire MOSFETs ( continuity buzzer test & ohms test) I found the result wasn’t encouraging as the YouTube tutorial person said that the Reading should be over 13 k ohms. The multimeter reading that I got for all six of my MOSFETs was around 9.5 k, ohms so does this mean they are possibly be on there way out?.
Also I am looking to replace the MOSFETs for new ones I’ve tried looking online but I’m stuck with the numbers on the MOSFETs. The main number is HY1707 but there is a second row of numbers. Are the second row of numbers important?.
I also heard online that each phase wire has a positive and a negative to it. is this correct? And if so how do I identify which one is + and which one is- ?.
I have provided in the picture what is wrote on each Component on each side of the blue yellow and wire phase wires. I hope this helps. If the mosfets are on there way out can you point me to an online retailer but not Ebay. Thank you. Merry Christmas and happy New Year.
