March 24, 20206 yr Hello - hope someone can give me advice as I'm not technical at all ! I have a heart condition so regular cycling is an out for me but I have a Pendleton Sommersby e bike and as luck would have it the battery has just gone and also Halfords is if course now closed ! I've noticed I can buy new batteries on Amazn which say they are compatible with my bike but I don't know which are - if any ! Money us tight and my bike is a total lifeline so just wondering if anyone knows which battery I can buy ? Thank you !!
March 24, 20206 yr When you say your battery has "just gone", do you mean it has suddenly stoped working? This normally means a bad connection or blown fuse. Does it still take a charge?
March 24, 20206 yr Author No it's only charging to two bars. To be honest I'm very unhappy about this as this was a replacement from Halfords after my last battery completely stopped charging - its reconditioned and has lasted about 4 weeks - of course Halfords is now closed
March 24, 20206 yr Show us a couple pics of your battery and charge esp the charger to battery connector, a side on one and one of the bottom discharge pins. You should be able to buy any generic one with the same voltage, it can be of any capacity ah/wh. The important bit also what area do you live in as someone may be able to assist. Edited March 24, 20206 yr by Nealh
March 24, 20206 yr Author Thank you!! I'm based in a little village in the middle of nowhere Northamptonshire. Attached some pics
March 24, 20206 yr The charge pin is XLR 5 pin, the battery is a phylion cased one so needs to be the same case to fit your rear rack. You require a 36v nominal battery and it doesn't have to be 8.7ah/312wh capacity battery it can be any capacity you like, more ah/wh just means more range. Your old one later on needs to go back to Halfrauds to be replaced or have the price refunded.
