I have a folding E+ E bike that I bough cheap as a non runner. You could smell the burn from the controller. To find identical controller was difficult but I found a used controller sold as working from almost the same bike. This has different connectors to my loom but came with the original PAS snd Led Display So apart from the brake switches it all connects.
So I fitted everything and it all lights up. When I pedal the front wheel gives a very quick boost to a fast speed and then freewheels to a stop. When it stops if the pedal is still turning it starts again.
someone suggested as the PAS connector had different colours apart from the red to try changing them. I did this but then it didn’t work at all.
my original controller had i think a 6 pin Julet connector but 9 pin at the motor.
the replacement has 9 pin from the controller all the way to the wheel.,
not quiet sure what to do next.
Will a thumb throttle fit where the PAS connects ?
thank you
Thank you.
thank you
Thank you.
