Hi all,
Just bought a Woosh Bafang G06 fat kit for my fat bike with 26" wheels.
I'm about to order a 7 speed cassette for it. But need help on deciding which to get. The Bafang G06 hub requires a cassette and looking at my options I'm getting confused!
The bike is currently fitted with a Shimano MFTZ21 7 speed 14-28T freewheel, a single 44T front chainring and Tourney rear derailleur.
The bike will be used 30% on the road, and 70% on trails. There are quite a few hills around me, but I can pedal quite hard if needed and have got up some steep hills with the fat bike without a motor (just).
I believe that the following are my options?
Shimano CS-HG200-7 12-32T
Shimano HG41 7 Speed 11-28T
Sunrace CSM63 7-Speed 11-28T
SRAM PG 730 7 Speed 12-32T
Does anyone know if the above are suitable/compatible and given that they have different cog sizes to the current freewheel will I need a different chain length and if so what/how do I go about making sure I get the correct length?
Opinions/advice would be much appreciated as this is my first rear wheel build, plus I have never changed a rear cog setup before, so am quite confused about what to get.
Images of the G06 hub (9 spline) and current freewheel if it helps:
