HELP _ GreenEdge CS2/16 Replacement Rear Hub Motor details
rayhertford
May 30, 2017
Hertford
Hi All
Does anyone know where I can purchase a new rear Hub Motor for my Greenedge CS2/16 Bike?
It's a 36 Volt DC, 250 Watt 26" motor. It looks like its made by Suzhou Xiong Feng Motor Co. in China
Does anyone know which model of motor was fitted into the Greenedge CS2/16?
Looking at a website I think it may be one like this, but wouldn't have a clue as to where to buy one from.
I've also noted that people are saying it might be able to be repaired? Something about fitting a new clutch kit?
Any help would be greatly appriciated.
Ray
8,533
You can fit any hub motor as it will work Xofo & Mxus like most others also are clones of Bafang hubs, Xofo tend to be OEM only so getting spares may be hard.
8,533
8,533
If interested I have a brand new Black unused freewheel hub motor in my garage, still in it's box. It may even be a Xofo xfv.
rayhertford
May 30, 2017
Hertford
Many thanks for your help and information Nealth.
How much would you want for the hub? And would you be able to post it to me by say Hermes or similar? Obvoisly I'd pay for the postage.
Just to confirm, it is for a rear wheel?
Thanks again
Ray
8,533
I will have to search for it in the garage, take a pic or two and confirm the motor designation. I do know it takes a threaded freewheel cluster.
davell
154
64
Doncaster
You haven’t said what is wrong with your current motor. It could be something simple to fix and could potentially not be the motor. . A new motor has the complication of getting the wheel laced. How many miles has the motor done ?
8,533
I'm not sure now what make the hub is I have got it, is a Mxus or clone of one originally I bought it to electrify a bike for the wife but she wasn't interested so it has sat in the box for about 4 years. I bought it form Bankrupt bike parts and seem to remember it being sold as a Mxus but can't be 100% sure.
The motor weight is 2.9kg, flange dia is 136mm and spoke hole dia is 129mm.
It has rotor fixings.
Drop out width is 135mm.
Apart form the these markings there are no other ones on it, it was sold a s a 250w hub.
Motor cable is standard 9 pin Julet sequence.
The hub has never been laced up as the spoke holes are clean and unmarked, there is some minor cosmetic marks on the flange. These must be handling marks and were present from the vendor.
8,533
Including postage it would have to be £90.
