Now here's an unusual one, l've never seen it discussed.
My cycle helmet is a standard type and it's fine at lower speeds, however at speeds of 15mph the wind roar is actually quite excessive, worse than my motorcycle helmet.
When descending hills or riding into the wind it's even worse and a little investigation revealed it's the straps that sit in front of your ears.
The wind lifts then and makes the roaring noise, l can't seem to shut it up unless l hold the straps flat against my head.
Has anyone else had this? lf you turn your head at an angle the noise stops. lt can't be good for your hearing and obliterates any other noise such as cars behind or other cyclists etc.
l've got three cycle helmets and they are all the same in this respect.
