Hi, I'm from Stoke-on-Trent ( the rumour going around that Stokes shut isn't really true), I'm 64, Had a stroke a few years ago and basically been pensioned off to play by myself (I said "by" myself). I consider myself lucky really, just watching the news each day reminds me I could have ended up in a far worse position than I have.
I found this site searching for information, Ive been building electric bikes for about 4 years now and I understand all the basics. What I am not savvy with is the electronic terminology mentioned in adverts like everyone reading knows what the hell they are on about. Most of us know what a hub motor is, if you do please nod your head, then they are on about amps versus watts and ruddy phase angles and then I have to have a coffee because I no comprendo.
That's my reason for joining pedelecs.co.uk, so I can read through the forums and pick the brains of those who know a lot more about the subject than I do, never too old to learn.
I was on google last weekend trying to find an answer to my latest problem, I bought a 1000w controller + LCD from Hallomotor.com and no matter what I do the motor which is only a few months old will not run, no sign of life nowhere, no throttle, no PAS, but all is not lost because the LCD works!!! The LCD is correctly set up according to Hallomotor instruction sheet and the now many emails to and fro but no power to the hub..
......bugger. So google lead me here to a thread on these hallowed pages where one guys trying to assist another with exactly the same problem. I read through it not understanding all the terminology, but nodding my head as if I did because my grandson was watching, and then I had a coffee.
I'd noticed on the new controller that the hall wires are as thick as the others, where they are normally 5 very thin sad looking things, that brittle ally wire that breaks if you look at it funny. The PAS and throttle are identical apart from the connectors, female on the throttle (oh the memories
) and male on the PAS wires. I wondered if maybe the factory had fitted the connectors to the wrong wires, could have a technician with a hangover or a robot with a coolant problem, you never know. I made up some leads to cross connect them, and there you go, it still doesn’t work. Checked my emails and Hallomotor are asking for photos of the wiring connections I’ve made, did that, and included a photo of my original controller, showing the label stating ……yes its 48v – yes its 1000w – and that its marked phase120, sent it and next morning had the reply as follows…………”hi,
Your motor is not compatible with our controller, our is hall angle 120 degree type not phase 120 degree. You can return it to us for a refund(after deduced our dispatch shipping fee about $15).
Regards”
The controller description on the site doesn’t mention degrees of either hall angle or phase, when I first told them I couldn’t get it to run they said “check your motor is 120”, they didn’t say hall or phase. I looked, saw 120 on the controller label and said yes it is. This is where I get stuck, what the hell is the difference between hall angle and phase angle? Why doesn’t it state clear requirements on the site to match your motor before its sent half way round the world with the shipping costing as much as the item………… not to work? Now they want me to pay for return shipping and charge me $15 (about) for the privilege. Well thank you sir but no. I’ll keep the damn thing until I come across a motor that it will run.
Sorry people did not intend to type a novel moaning like a bloke from Stoke that’s had a stroke, but I have. Regards, Gray.
I
Regards”
I
