Hello from Warwick
paddyo1963
Hi My Name is Patrick,I have always had a bike but for work I need an Ebike as I do 3.5 miles each way to work on me bike and it's a bit hilly ,then walk and average 10mile a day so I'm as green as it comes to ebikes .I have been reading so much regarding ebikes . so I do not want to spend a fortune but would like something with decent parts on that will not go Pete tong after a year or so .thankyou for letting me join
Ghost1951
1,045
353
Glad you joined. You will get good advice here.
2,807
This one has smaller battery (around 25 miles), but has a rack.
This one is 48v, so has a lot more power for climbing hills if you're heavy or weak:
paddyo1963
Thank you for the links will check them out
Saracen
532
Any replies are pointless unless you state how much you can spend and what you will use it for
paddyo1963
£1000 ISH .il use it for work and getting around locally. I do take me bike away in the UK for holidays
matthewslack
1,758
1,278
Your commuting requirement is so short anything will do. If you have secure storage at work, then maybe let other likely uses determine what you buy. If you don't then cheap and cheerful so the other bikes get pinched first!
