Has anyone used Swinging Wheels stabilisers on e-bike?
I am now giving up with two wheel e-cycling because of balance issues. I'd like to keep doing some sort of cycling and am wondering whether to add (if they fit) the Swinging Wheels stabilisers which are sprung www.swingingwheels.com They are not in contact with the ground all the time and they allow for leaning into corners. My riding area is in the North York Moors National Park so mostly up and down including a 1 in 4 hill. Has anyone had experience of Swinging Wheels? My alternative is to move to an e-trike although I am aware the transition can be quite challenging in terms of riding style. Comments on this and other suggestions for safe riding would be very welcome.
The maker highly recommends you take a test ride, and I can see why. It's quite a step-change in how a bike may handle and may not suit you at all. Have you talked to their UK dealer in Eastbourne? They may already have customers in your area (or at least closer) who might be happy to let you have a go?
I might have laughed at one time but once medical balance issues hit, it's not so funny falling off a two wheeler . Going up a 1 in 4 hill is pretty slow even with an e-bike
That's a great idea. I have been in correspondence with the UK dealer but not thought of asking if he had any northern customers. Thank you
When my father reached his late eighties, his balance became a problem. He had cycled all his life, it was his great passion. He changed from human power to ebike at 81. so with the balance problem, he decided he would buy an E tricycle, but could never control it. Over 70 years of balancing on 2 wheels, he just could not get used to 3 wheels and kept going straight on at corners. He was bitterly disappointed. I would certainly try and get a test ride before you buy. It's a shame we did not know about Swinging Whels he may have been OK with those.
Edited by flash
I have reservations about those stabiliser things. The moment a stabiliser wheel touches the ground, your steering effort reverses, as it changes from a bike to a trike. When you change from a bike to a trike, you have to steer the opposite way, which is why people like the guy mentioned above have problems. You have to re-train your brain. Doing it several times in the middle of a ride is going to confuse a lot of people.
I think a recumbent trike would be much better because the steering is completely different, like switching from a bike to a car. Your brain knows they're different vehicles, so it loads up the appropriate program before you start.
I am 66 but have no issues, yet, this is one choice I may not like to make BUT, if it is a choice between cycling and not, there is NO choice :)
Have you ever tried oner ?
No, but I have a pretty good understanding of physics, and I have ridden several trikes - recumbent and upright. A recumbent trike with vertical bars is fairly intuitive regarding the steering, but you have to retrain your brain to ride an upright one because of the steering effort reversal.
When you're on two wheels, you push the bars to the left to turn right, and harder to the left to tighten a turn. On three wheels, you turn the bars to the right to turn right and harder to the right to tighten the turn. A bike with sprung stabilisers behaves as a two wheel bike when you initiate the turn and a three wheel one when turning. You'd have to turn the bars to the left to initiate a right turn, then right to tighten it at some undefined point of lean.
You can learn to ride any bike or trike, including a bike that has a reverse steering mechanism that you see at shows. It just takes time, but you're very vulnerable during the learning period.
Edited by saneagle
Thank you all for your comments and suggestions. Swinging Wheels are from the Netherlands and the only supplier in the UK that I have found is in Eastbourne. He was very helpful and showed me with photos all the measurements to take of the rear of the bike to discover if the SW would fit. This, I am about to do. I also found a YouTube video
Your comments after seeing this would be welcome. To me, the fact that the height of the wheels can be adjusted and don't have to be on the ground permanently could be an advantage. There may be a relationship between confidence and wheel height as I get back to riding.
At 1m 17s, the daredevil stuntman wearing sunglasses doesn't appear to need to countersteer, for those small turns at least. I wonder how a bicycle would handle with stabilisers either side of both front and back wheels?
https://www.youtube.com/watch?v=pKLECDL5Rp0:76
Looks like he'd have to countersteer for this sort of turn (after the 18 second mark).
https://vimeo.com/874431040:18s
Edited by guerney
You don't and can't counter-steer a trike. That's the problem cyclists have with them.
Fixed stabilisation may be OK on flat roads. But cambered surfaces, slopes and inclines more problematic.
Mission Cycles are active in this sector.
https://youtube.com/@missioncycles5481?si=2lgNnd8S0VdUDwrp
As are Van Raam, at a premium!
https://youtube.com/@Van_Raam?si=iVLXDc6jMXx_0sOo
Electric Bike Schools 2 pence on 3 wheelers..
The dangers
You pays your money and takes your choice. Lower centre of gravity, more stability.
The solution is for the rear axle to temporarily reduce in length according to trike tilt while going around the bend, bringing the rear wheels closer together?
I wonder if there are any trikes with the two wheels at the front which makes them much more stable.
Many recumbent trikes are like that, and they have the vertical bars that prevent your brain from trying to steer them like a bike.
https://www.icetrikes.co/
There have been motorcycles that had two wheels at the front and one at the rear that could be lent over into a turn that I believe worked very well.
https://www.vanraam.com/en-gb/news/front-tricycle-for-adults-by-van-raam
I think quite a few others as well. Interestingly, they don't mention '2 wheel-like' steering as one of the benefits.
A tricycle with two wheels in front has many advantages:
  • You can easily estimate the width
  • It can be a good alternative if you have difficulty getting on and off your current bike.
  • On a tricycle it is not absolutely necessary to get off when you are (almost) standing still; you can safely cross the road while sitting on the saddle.
  • Have you come to a stop? Then a tricycle does not tip over as is the case with a bicycle.
I've ridden one. They lean just like a motorbike. The steering and balancing are the same. You counter-steer to initiate a turn. The only additional thing is an electronic lock that prevents leaning when you park or want to stop for any length of time. OP needs a bike that doesn't lean because the problem is balance. When you have a vehicle that doesn't lean, the steering effort reverses, which is very dangerous when you first start riding it unless you've never ridden a bicycle. The more experience you have of riding a bike, the worse it is.
These newfangled thru axles look quite strong - why not make a longer thru axle, bodge two wheels either side of the front fork? Wheels dished towards the bike if necessary, so that the tyres are about 8 to 10 inches apart. For wider apart front wheels, make a stronger secondary axle, and bolt underneath? Twin low pressure balloon tyres at the front might result in a bit of a tilting effect, but not enough...
Edited by guerney
You'd get the same problems of learning to ride it as you would with a trike. In fact, it would probably be worse becayuse your brain will think it's the same bike and try to steer it the same, which won't work.
https://www.epicwheelz.com/collections/electric-tricycles-for-sale/products/pfiff-24-pronto-7-speed-adult-electric-tricycle-two-front-wheels
$4299 before tax, shipping, import, etc, ouch!
Tilting trike w 2 front wheels got redesign and price doubled, as per usual. No pedals though, so not legal?
https://ridemylo.com/
Van Raam "easy rider trike"
"From" €3206 plus tax, shipping, etc
https://www.vanraam.com/en-gb/our-bikes/tricycles/tricycles-for-adults/easy-rider
I'm sure there are many more. They're just a lot more expensive coz not made in volume.
One can buy the TReGo front kit to fit Qr dropouts, not sure if one can lock out the lean action.
Edited by Nealh
