Hi all.
I'm sure this thread may have been flogged to death but I truly can't find any info.
I'm at my wits end here....
Here's the issue.......
The bike , "e swift" 36v, has been utterly faultless for years.
But now it's got a bit of water ingress in the display unit.
Which is causing it to play up somewhat, but upon removal of the unit, cleaning and drying out, it's fine.
I have been led to believe that just because a 'similar' replacement unit has the same 5 pin connector it will more than likely be configured differently.
I'm basically having a real nightmare trying to get one that will work.
I intend to get a couple of new ones and "pot" them with resin .(avoiding the buttons obviously). Which will hermetically seal them.
I've found one nearly the same but it has a headlight button on it which mine doesn't. So still not quite right, and didn't work.
The only one that works is the original when it's dried out you see.
I hope one of you learned friends can point me in the right direction.
I have attached 2 pics that will help.
Thanks in advance all.
