Hi All,
I've booked a test ride with one of these Haibike sDuro Hard Seven as it appears to tick many of my boxes. Does anyone have any experience or thoughts on this bike?
No, not the hard seven. The machine I have is the sDuro Trekking, so I can only speak about that.
The first thing I will mention is the noise level from the Yamaha PW drive. When new, the sound was a sort of metallic rasping, although the amplitude (or whatever the proper word is) remains constant throughout the power band, unlike the Bosch classic drive which rises to a screaming crescendo at the maximum 60 nm of torque. My machine now has 120 miles on the clock and already the drive has quietened considerably, the "newness wearing off" as they say.
My regular ride includes a ½ mile climb, 18% slope at the steepest point. Another bike I have with 50 nm at the crank ascends the hill at a minimum speed of 11 mph, another with 60 nm of torque climbs the hill at 12 mph. Both of these machines powered by the Bosch classic drive. Therefore, I expected the sDuro with 70 nm under the bonnet to cruise up the slope at 14 mph minimum....but it took five attempts to achieve that speed. Here's why.
The Bosch classic drive has only a single-stage reduction of 8.38:1 into a 28" wheel. To get the motor armature speed up into it's power band the pedals have to be spun quickly, not super-fast, a cadence of 75 rpm will get the classic drive screaming it's little heart out. The Yamaha PW drive needs a different technique.
The first climb with the sDuro, I adopted the same technique of "spinning" up the hill, and failed to better 13 mph. I knew the 70 nm's were there as I had often seen the power graph shown on the display right at the top, when spinning up the hill I could not get the bar-graph much more than half way the scale....I was spinning the pedals too quickly. On Thursday last I finally cracked it. This time I climbed the hill in a much higher gear, the rpm counter (cadence) on the display showed 55 rpm, the power meter in the top left hand corner on the display hitting the top of the scale with every pedal stroke (70 nm)....minimum speed at the 18% point, 14 mph....result!!
So, if hill climbing power is what you are looking for, keep the cadence down in the fifties. The Yamaha drive clearly has a multi-stage reduction gearing...pedalling too quickly will spin the motor out the top of it's power band.
Power consumption is of course subjective, for me, over a seventeen mile ride including ascending that hill as fast as possible is 9.8 watt-hours per mile. I would confidently expect in excess of forty miles on a charge for an old codger like me.
Hope you enjoy your test ride, looking forward to hearing your first impression of this excellent drive system.
Have fun
Bob
