Hai Xduro FS SL electric mountain bike bought when I was based in Germany. They are all the rage out there. Bike is 6 months old looking to sell to fund the model above this one.
Size - 17"/44cm(alloy seatpost which can be cut down so lots of adjustability-would suit from 5'5 to 6'2)
What there website says
XDURO ‐ Radically Electrified
There is a good reason behind the performance eBike boom: the Haibike XDURO range. The first models were introduced in 2009 and have been a success ever since! It is by far the most successful and comprehensive ePerformance range on the market.
Our secret? From the very beginning, we focused on combining sporty mountain bikes with the dynamics of an off‐road compatible motor. The result: a brand new riding experience! Limitless and pure riding enjoyment! Your own physical power is still an essential component of the XDURO riding experience. You can go all out or simply enjoy cruising along – it’s completely up to you.
Multiple Award‐Winning Design
The XDURO design promises what the technology delivers: the Pedelecs are not oversized mountain bikes, nor are they shrunken motocross machines. They are consistent, well‐proportioned performance eBikes. Their design has won the iF Design Award and the Eurobike Award, and has also been awarded the Extra-
Energy test seal of approval. You get what you see!
Equipment
Motor
Bosch drive unit 36 Volt, 250 watt
Battery
Lithium Ionen 36 Volt, 300 Wh
Display
Bosch Intuvia multifunctional display with operation unit & push-assistance
Fork
Rock Shox Recon Silver Air, PopLoc, suspension: air, dampingil,Travel:120mm
Rear derailleur
Shimano SLX M 675 Shadow Plus, 10-sp
Shiftlever
Shimano Deore SL-M 591,Rapidfire
Crankset
eQ Alu 38T
Bottom bracket
Bosch drive unit 36 volt, 250 watt
Sprocket
Sram PG 1030, 11-36 T, 10-sp
Chain
Shimano HG 54
Brake lever
Magura MT 2, adjustable reach
Brake (front)
Magura MT 2, hydraulic disc brake, 180mm Disc
Brake (rear)
Tires
Schwalbe Racing Ralph Evolution, Snake Skin, 26x2,25, SV-Valve
Rim
Rodi CC40 disc,alloy double wall
Hub (front)
XLC Pro Disc, 15mm through axle
Hub (rear)
XLC Pro Disc, 142/12mm through axle
Spokes
DT Swiss Competition, black 2,0/1,8/2,0mm
Handlebar
XduroLowriser Alu
Grips
XLC Sport lock on grips
Stem
eQ Alu, A-Head
Headset
FSA SX, A-Head, semi integrated 1 1/8" - 1 1/2"
Saddle
Xduro Light MTB
Pedals
XLC MTB
Rear shock
Fox Float CTD BV LV, 110mm
Frame
Aluminum 6061, hydroforced tubes, reversed angle Bosch-Interface
Total Weight
21,3
Equipment
Motor
Battery
Display
Fork
Rear derailleur
Shiftlever
Crankset
eQ Alu 38T
Bottom bracket
Sprocket
Chain
Shimano HG 54
Brake lever
Brake (front)
Brake (rear)
Tires
Rim
Hub (front)
Hub (rear)
Spokes
Handlebar
XduroLowriser Alu
Grips
Stem
eQ Alu, A-Head
Headset
Saddle
Xduro Light MTB
Pedals
XLC MTB
Rear shock
Frame
Total Weight
21,3
