Motor Diameter: 10.5 Inches
Motor Case Length: 11.25 Inches
Motor Shaft Length End to End: 12.25 Inches
Motor Type: Brushless Permanent Magnet
Brushes: No
Weight: 150 lbs.
Max Voltage Input: 360 Volts
Integrated Sensors: Encoder, temperature
Rated Torque: 280 Lb Ft Peak (w/150kW controller)
Rated Power: 210 HP Peak (w/150kW controller)
Max RPM: 10,000
Drive End Shaft: 32 spline 35.5 mm
Thermal Cooling: Internal oil pump with water heat exchange
Warranty Period:1 Year
haibike should have gone with that would you pay 20k+ for it tho ?
