GTech ebike tuning?
silles
47
46
Are there any tuning options for this bike?
I'd like to increase the speed to at least the legal speed limit, right now the motor cuts out around 14 mph ...
5,786
Change your tyre size (the tyres on the bike). A 6-7% error is well within the speed difference commonly seen even in cars. They seem to be respecting EN15194 to the letter because power is supposed to diminish and cut out before or up to 25 km/h.
Andy-Mat
2,214
564
78
On some bikes, the controller is made for several wheel sizes, therefore setting a smaller size than actually fitted, will give you a higher speed!
But you might be illegal, but at least you can "lie" and say it changed itself somehow!!
Its the cheapest method that I can think of!!
But as I said, in most countries (all EU at this time) illegal!!
Remember, you will regret this if you have a hefty accident!!
Regards
Andy
silles
47
46
not sure if i can fit bigger tyres due to the slick mudguards, but it might worth a try
if i'd go from 700x38 to 700x56 to
the circumference would go from 2192.83 to 2305.93 which is 5% gain in speed at the same RPM.
silles
47
46
Regards
Andy
the controller is not programmable, this bike does not even have an LCD :)
Bjn201
Hi All, just wondering if you managed to remove the speed limiter in the end?
This is just for use on private land only.
