There is no cut-out sensor. The cut-out is in the controller's software. You'd have to remove the CPU, then nothing would work.Hi
I am looking to remove the pedal assist cutoff sensor/part. I want the motor to give me output as long as I pedal without cutting out. Below is the circuitry. which item do I need to remove?
