Greetings from Kernow
Pencoys
Jun 12, 2019
Kernow
Hi, Pencoys from Kernow here. New to e-bikes. I bought a non runner and need some advice about how to identify the fault.
Its a Kalkhofff Agattu with an Impulse 2 motor. I understand there were issues with the motor, but I suspect either the battery or the control system as the bike refuses to turn on.
anyway. I'll peruse the forum posts for a possible answer before requesting specific info/help.
cheers, Pencoys
8,843
First of all good luck with that one and welcome to the Fora.
Not familair with their batteries so don't know if you can simply stuff probes in to the discharge to check voltage, battery likely should be ok but may have a blown fuse. Fuses can be ext or int.
Help regarding Kalkhoff's will be along soon I expect.
